0411 ecu guestions
0411 ecu guestions
Ok, first i don't know nothing!!! sorry I'm very green to the ls world. can I take the 0411, and respected harness and do the 4 wire hook up method and start the engine and with out it being tuned, re flashed. I've tryed to reserch this but here i am. is there a v.a.t's that will stop me? or are they turn key on a swap?
thanks for any help and direction with this
i'm wanting and am pretty dead set on the holley high ram, ls6 or slighly bigger cam. possibly 317 heads. the engines a 02 5.3 bored .030 to clean it up. it was only a long block when i got it. so i have nothing more... i believe if i have the vats cleared it should atleast run. maybe not well cause of these mods,but on a stand to get things rolling i can go from there. it'll have a 70'ish turbo and high stall to get it in the power. i understand i'll have to put better springs in it so it'll rev and not go into float. i'm looking for about 72-7500rpm.
thanks for help.
thanks for help.
The turbo Isn't going to be on it until the I have it some-what sorted out and in the truck...
what sucks for me is I got only the long block, nothing else, so Im looking into parts from the wrecking yard to come by all the sensors and that. really don't care to buy new then upgrade them.
whats a good injector up to 600hp on a 70'ish turbo?
