Replaced knock sensors now problems please help!
Old 06-16-2016, 09:05 PM
caturnbull1's Avatar
Default Replaced knock sensors now problems please help!
First off hope this is the right section. So a few weeks ago my#2 knock was throwing a code. I changed both the wire harness and intake gaskets. Put everything together to torque specs. Now the car idles fine and cruises fine but if I get on it it runs like crap, backfires and starts a chirping noise. I reset the pcm and did not help. What next?
Old 06-16-2016, 10:29 PM
67Lark's Avatar
Did you scan it to see if there are any other codes and double check everything that you pulled apart?
Old 06-17-2016, 07:13 AM
No codes have popped up. I've checked everything but will probably pull the intake off and check the gaskets.
Old 06-22-2016, 11:27 AM
Found the problem. Had a broke spring
Old 06-22-2016, 11:44 AM
67Lark's Avatar
Yeah that will cause issues, glad you found it though
Old 06-27-2016, 08:15 PM
me too! went ahead and ordered springs seals and retainers
Quick Reply: Replaced knock sensors now problems please help!
