Firing order, is this odd?
So I bought my car used with 65k miles on it and I was bored and decided to run through hptuners to look at my stock file... This is what I found... The car sometimes would run rough at idle. Which one is correct? The top image from what I can tell is the correct firing order. Why would anyone mess with the firing order? When I pulled my plugs they all looked perfect.
the PCM is hardcoded to fire the injectors and coils in a particular sequence, the firing order tables that are shown are usually for misfire disagnostics but nevertheless the top sequence is the correct one..
