P0171/ p0174 need help
Old 08-18-2016, 12:48 AM
94_ltx's Avatar
Default P0171/ p0174 need help
I have an 04 gto that is running lean on both banks. I checked fuel pressure and it is at 60, ltft's are +25% at idle and drop significantly when rpm's are held. Stft's are at 10%-12% and drop to 4%-6%. Any idea what could be the problem.
Old 08-18-2016, 10:28 AM
LS1Tech Sponsor
06MonteSS's Avatar
any mods done to the car??
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 08-18-2016, 11:16 AM
2xLS1's Avatar
Smoke test the intake and exhaust system.
Old 08-18-2016, 11:49 AM
94_ltx's Avatar
Just k&n air intake, previous owner deleted resonators and mufflers but that's it. I don't have access to smoke machine but I was thinking maybe intake leak, I will spray some carb cleaner around it and see if I get reaction.
Old 08-18-2016, 01:44 PM
LilJayV10's Avatar
what your STFT and front 02's when you are spraying carb cleaner. If they start to go negative you found your vacuum leak.
Old 08-18-2016, 02:58 PM
94_ltx's Avatar
Any other places besides intake that might have a vacuum leak
Old 08-18-2016, 03:55 PM
2xLS1's Avatar
I don't know why anyone would want to spray caustic carb cleaner on their engine. Smoke is the only reliable way to find leaks.
Quick Reply: P0171/ p0174 need help
