Mounting the GM Plug n' Play wire harness fuse/relay box?
What is the cleanest way to mount the GM Plug n' Play wire harness fuse/relay box? It will be sitting on a flat surface.
There are a number of clip points molded into the side of the box, so it would seem there would be a variety of "factory" mounting clips available. Part numbers? Sources? Other mounting approaches?
Thanks.
Thanks.
Depending on what you are installing it in and the length of the harness many people mount them under the dash behind the glove box. As far as mounting brackets are concerned you could look at what ECU model you have and find out what vehicles it was used in then look at sources like salvage yards and E-bay for the mount.
