c5 flex fuel questions
#41
One thing I noticed with the '04 van OS is there is no 3 bar with RTT....which is kind of a bummer because it makes part throttle tuning a breeze. Might do most of that in 2 bar RTT which it has and then copy pasta the info over.
Also the main VE table is not nearly as detailed as my current 3 bar tune on an 0411 pcm...far fewer cells.
#42
Lol we are almost done man! Its been very time consuming but it'll be worth it. Youre in PE too or another branch of engineering?
I've never really been a fan of RTT but maybe its because it slows down my pc considerably, maybe its time to upgrade lol
And yeah the table has less resolution, you can normalize the KPA values to gain more resolution down low, and less up in higher kpa values. If you arent sure on how to normalize i can show you, i do it all the time on e38s
#43
manufacturing engineering, at night. it'll be nice to have a life again.
ideally i'd have as much resolution as possible from say 50kpa to 200kpa.
yeah the RTT really taxes my cheap lenovo t420, but i only use it once in a while.
I'm still setting up the tune to match my current tune as closely as possible.
I did get the sensor plumbed, ought to wire it tomorrow and play with it this weekend
#44
I see the Flex Fuel spark table only goes to .88 cylinder air. What happens to the spark timing when using the 2 or 3 bar OS? When you hit the bottom of this table does it continue to carry that spark advance over to the high octane table?
I have the 3.24 version of HPTuners and the Blend Factor table does not show up.
#49
I'll upload it when I get home. I was able to see the Blend Factor table when I first downloaded it. The next day it was gone so I know I should have it. IDK what happened for me to not be able to access it now. I did the 3.2 beta upgrade again just to see if something got lost in translation with no luck.
