bad pcm issue.
bad pcm issue.
ford explorer 2008 4.0
problem is rough idle engine hesitation at idle or when stop at traffic light.
codes showing
4 oxygen sensor.
EGR valve.
purge control valve.
yesterday i change the 2 front o2 sensors but no difference and the codes still shwoing.
i tried change fuel pump
clean fuel injectors.
spark plug.
check coil body from another same model car.
change fuel filter.
is this the pcm problem?
codes showing
4 oxygen sensor.
EGR valve.
spark plug.
change fuel filter.
