MAF placement
MAF placement
Hey all- I have a 6.0 LQ4 engine i plan to run turbocharged with the factory fuel injection and hptuners. Is there a certain distance I need to place the MAF from the turbo outlet or from the blow off valve? I read somewhere that people are using some wires from the MAF SENSOR and running them to a larger map sensor thanks! Andrew
I would put the MAF as close to the throttle body as you can. So, post BOV. As far as the wiring, I have never heard that before. Maybe what you are getting confused on, is that vehicles that have a 5 wire MAF, people will cut out the 2 wires that deal with the IAT sensor, and run them to an individual IAT sensor in a different location.
why bother using a maf sensor? buy a compatible 3 bar map sensor and forget about it.
if you're hard pressed on running a maf, make sure to install AFTER the bov and on a straight piece of pipe. If you convert to a card style MAF such as an ls7, then try running a 4" pipe to increase the range of the sensor for "higher" boost levels.
I have no idea! Obviously this is my first turbo ls swap and I have never tuned anything before. I am buying hptuners just for this project with the bonus of deleting torque management out of my dad's 08 ls3 c6 and my 03 c5 z06. Why wouldn't I want to run a MAF? I do have a 3 bar gm map I bought when I was going to go blow thru carb on the old 355 sbc.
I am planning on using the stock 2000 lq4 MAF on the truck currently.
Thanks
Later,
Andrew
it means it wont read any more air after a certain "time". The max "hypothetically" speaking of 512 g/s would be the max amount of airmass the mass air flow in your car can read. Therefore, if your turbo or engine, or whatever it is, is leading to an amount of say, 550 g/s, those 50-12=38 grams of air wont be accounted for by the meter. Therefore leading to a hackjob in your "tune" by relying on temporary fuel enrichment that might change the following week due to density, barometric changes for that particular day.
A 3 bar map sensor to tune your vehicle would be a better way to tune it, unless your car doesn't reach the limit of the airmeter.
What do you mean run out of frequency? I am prob wrong but I thought the MAF output was voltage? Either way are you saying it will max and not read a difference with more boost/airflow?
Thanks
Later,
Andrew
Thanks
Later,
Andrew
