interchange pcm from 5.3 to z06
i had an 05 5.3 motor in my 37 ford coupe and i am changing it out to a 04 z06 corvette motor can i use the wiring harness from the 5.3 it is pin out at the plugs the same as the zo6 harness also can i reflash the pcm or do i need the z06 pcm
2004 Z06... Meaning a LS6?
If it is indeed a Ls6 you can use the same computer from the 5.3 with a few wiring changes to the harness.
Do you plan to keep the DBW on the new engine or you are going to convert to DBC?
