red and blue plastic
The whole 80 pin connector assy ? Ebay. Junkyard. The connector bodies are the same between the red,blue,green types. You can use a pick to remove the coloured shrouds from the body and swap them etc.
The removable transparent coloured pieces have the keying ribs on them. They are technically known as "TPA". Part numbers 12176410 12176408 The main metal/plastic housing does not have keys and are interchangeable.
OP, you can get those from mouser.com if you don't want to go junkyard diving.
Restricted User
sorry for the confusion, the BODY is the same, the colored "clips" that go on the pins DO change. The keyway changes, but you can get a knife and "modify" it to work is what i meant. In the case of a green to red or red to green. For a bench harness, you only need the blue connected, and 99-07 they all have blue so no need to change that. As 2xls1 stated above me
Restricted User
