LS7 backfires at idle?
Old 01-22-2017, 10:38 AM
Bowtiejoni's Avatar
Default LS7 backfires at idle?
Hi guys,
I have stock crate LS7 with gmpp pcm. Headers and 3" pipes with short borlas.
After cold start, it bangs/backfires 5-10 times. Could it be too lean due high flow exhaust?
Any ideas?
Old 01-22-2017, 10:59 AM
brandon6.0's Avatar
any codes? Could be a number of things. Does it actually crank up fine? changed plugs?
Old 01-22-2017, 12:44 PM
Bowtiejoni's Avatar
I have not had change see any codes yet. Zero miles so far on the car. Brand new engine. It cranks up really fine but dont start immediately at cold.
Old 01-22-2017, 02:55 PM
Moderator
Darth_V8r's Avatar
Received 1,835 Likes on 1,145 Posts
Exhaust backfire or intake backfire? If exhaust, check for leaks
Old 01-22-2017, 03:34 PM
Compsystems's Avatar
If it does this during cold start then its in open loop, and not reading the 02's yet. So exhaust leak wouldnt matter at this point.
Does it have the same backfire after it warms up or after a hot start?
Its most likely a fuel supply issue causing it to run lean. Check your fuel pressure at the rail and see if its within spec.
Also make sure all sensors are plugged in including the MAF.
Old 01-22-2017, 03:57 PM
Moderator
Darth_V8r's Avatar
It would if its dumping fuel, sucking in fresh air, and then igniting the in burnt fuel.
Old 01-22-2017, 05:42 PM
brandon6.0's Avatar
^^ yes that is possible. Your best bet at this point is to get u a wideband on that thing and see whats going on. It should be in the low 13s on a fresh cold start and work its way up to 14.7 when it goes into closed loop around 150*.
Old 01-22-2017, 05:43 PM
brandon6.0's Avatar
check for a dead cylinder by taking a water bottle and spraying a mist of water on each header primary tube near the head. If its dead u will see the difference.
Old 01-22-2017, 05:54 PM
Moderator
Darth_V8r's Avatar
If it's intake backfiring I'd check your cool subharnesses for bent pins and possibly mismatched pinouts
Old 01-22-2017, 06:00 PM
Old Geezer's Avatar
A data log???
Quick Reply: LS7 backfires at idle?
