V6 to V8 PCM
Old 02-16-2017, 04:54 PM
blackdragonws6's Avatar
Default V6 to V8 PCM
Currently I am converting my 2002 V6 Y87 Performance package firebird into a WS6 Trans-am.
My question is, can I use my old PCM? An is there a way to install all of the V8 information or do I have to buy a whole new V8 PCM? If there is a way to install it how would i go about doing such things? Thanks in advance!
Old 02-16-2017, 09:00 PM
ScottyBG's Avatar
Are the last 3 digits of your PCM part number on it 411? If they are, your good to go.
Old 02-16-2017, 10:08 PM
Thanks, I'll have to pull the gray covers off of it to see what the numbers are. When you say good to go, what do you mean by that?
Old 02-16-2017, 11:42 PM
ScottyBG's Avatar
Means that you can tune that ECU to run your V8, by loading the correct tune for the LS1. You will still need a tune, but you can use your hardware.
Old 02-17-2017, 12:24 PM
I checked it today. it ends in 385. but it says blue, not sure if that makes a difference, the blue part I mean or if that's just referring to the connector color.
Old 02-17-2017, 01:29 PM
2xLS1's Avatar
You will need to get a 09354896 or 12200411 PCM that use blue/red connectors. Your V6 PCM won't work.
Old 02-17-2017, 05:54 PM
Is there any difference between those two pcms? I am building an LS engine I currently have a 5.3 LS block that I am going to bore out to a 5.7 engine so I am not sure if those part numbers on those pcms make a difference. I appreciate all the advice an help!
Old 02-18-2017, 12:42 AM
2xLS1's Avatar
09354896 was used in 99-00, 12200411 was 01-02 and a few 03. Some think the 0411 is better for some reason but I can see no discernible difference in the two. The OS you load in either of them will make more difference than either box.
Old 02-24-2017, 03:42 PM
Well Im looking at two different options. Do I buy a used ebay pcm with the last three of 411 from flashmasters and have them flash it for me? 89 bucks or do i buy a remanufactured one with no flash from autozone for 200 bucks which would be practically brand new, but then I'd still have to get it flashed and I wouldn't know who could do that around here.
Old 02-25-2017, 10:49 AM
travisn's Avatar
I got two 0411 ecu's on ebay for $10 each. (it's good to have a back up, especially when I have no idea what I am doing)
I can't help if you can flash a v8 to your current tune, but one of the ecu's I have is a v6, just wire it as described for that flash and it will work. The ecu I am using now came from an express van with single coil fire (or something, never looked into it). Well it wouldn't run on my ls1 until I got a camaro tune from the repository.
The benefit of having an 0411 ecu is it's popular so info and advice is easier to come by. That alone might be worth the $100 for a new ecu...
Quick Reply: V6 to V8 PCM
