timing getting pulled as I build boost, cant figure out where
So I have gotten most of the mechanicals sorted out and have begun some test fires.
Today I tried to build some boost on the sloppy brake.
As soon as I came up to ~90kPa my timing went negative 6 degrees. For the life of me I cannot see whats taking it out.
I need a second set of eyes on this thing. I'm tired and just cant see it.
Here's the log and the tune. I try and build some boost around the 3:30 mark and I loose timing right about 3:40 on the nose.
Check "Max Torque vs. RPM" in TQ management. I'd also zero Spark Retard vs. TQ Reduction. My bet is these tables are playing hell with the brake. Would explain commanded 22 degrees and seeing -9.5.
