98 pcm tire/gear wizard and 4:10 problem.
I'm trying to get the speedometer correct for 4:10's with hptuners. My tire is a 25.55 so I want to enter lower than a 6.3(lowest setting). I have the newest version of hptuners but on the lowest setting I'm 4mph off. Is this just because of the 98 pcm? Can this be done without the wizard somehow?
I switched to an 0411 pcm with my 98 swap, so I am not sure if this will help, but I imagine it must be similar (scaling the VSS signal)
http://www.hptuners.com/forum/showth...ing-VSS-Signal
