Going DBW-have two pcms
Engine is a '99 5.3.
I've decided to go DBW.
I have a harness and two pcms: (1st) serv no. 09354896
Hdw no. 16220610
(2nd) serv no. 12586242
Hdw no. 12583660
From what I've read the (1st) should work with DBW only. Do I have to use a certain tac module and pedal?
Hdw no. 16220610
Hdw no. 12583660
Which harness do you have?
Easiest route would be the second PCM with a truck harness, metal pedal with TAC from 03-05 truck will work with that PCM.
Wiring can be modified to suit your needs, so at his point you can do anything you want.
If it came with the 2nd PCM then it should be Green/Blue connectors and have DBW wiring already. This is your best option since 03-05 pedal/TAC is cheap and easy to find.
I'll double check the colors after work today. Already have the DBW throttle body as well.
-thanks
