Need info on purchasing an LT1 Tech 1 Diag scan tool?
Old 02-27-2017, 12:45 PM
Daniel Moody's Avatar
Default Need info on purchasing an LT1 Tech 1 Diag scan tool?
Hello,
I'm not a mechanic but I own a 1997 LT1 motor, pretty sure its Gen III.
Anyway, the LT1 is in a Mastercraft ski boat with a cadillac northstar ignition system.
My question is, can someone point me to tech 1 diag scan tool that I can use to look at the engine hours for the motor?
I see scan tools listed on EBAY, but I don't really know exactly what I'm looking for?
Thanks,
Dan
Old 02-27-2017, 04:38 PM
2xLS1's Avatar
I've never seen engine hours recorded or stored in any GM PCMs. What you need to identify is the PCM being used. Being in a boat I wouldn't be surprised if it isn't using a MEFI controller.
https://www.obd2allinone.com/mefitune.asp
Old 03-06-2017, 08:35 PM
sbcgenII's Avatar
You can see run time before a code was thrown. Don't know if the pcm records total time anywhere. Newer stuff probable does if it has a oil life monitor. 1997 is a gen 2. BTW. Do you have a picture of the computer?
Quick Reply: Need info on purchasing an LT1 Tech 1 Diag scan tool?
