the Z is killing me
Old 07-02-2004, 09:51 AM
spdrsr1's Avatar
Default the Z is killing me
okay.. so ive had my spec stage IIIi installed for about 2 1/2 months.. just the other day it starts to putter really bad, and revs to like 2500 and then pops and turns off.... i turn the key and it turns right back on. and does it again, the only reason i mention the clutch is cause the only time the engine revs like this is when its rolling...if i let it idle and play with the gas pedal i cant get it to do it again...only when its on the road.
can anyone help me with this issue, i dont wanna take it to a dealership cause i dont have the air system on and i dont know what they will say about it...does anyone know a dealership i can take it to if i cant get this resolved myself...
i take the car to auto zone to see what codes it throws, and here is what i got:
P0102 Mass or Volume Air Flow Circuit Low Input
P0418 Secondary Air Injection System Relay A Circuit
P1133 HO2S Insufficient Switching Bank 1 Sensor 1
the pcm thew these codes, would they have anything to do with my engine doing this.
Old 07-03-2004, 11:42 AM
spdrsr1's Avatar
anyone got a clue...
Old 07-03-2004, 12:38 PM
Team ZR-1's Avatar
Check for a blown fuse, bad connector pin or wires to the MAF or the MAF itself as being bad.
Old 07-03-2004, 10:45 PM
SmokingWS6's Avatar
Check to make sure you MAF is plugged in. If it is you'll either need a new one or have somebody make sure there is not a wiring problem somewhere along the line. Also the o2 code pretty much means the o2 is dead.
Old 07-06-2004, 08:37 AM
spdrsr1's Avatar
yea its connected..and being as how its still the stock one, and i have never even messed with the wires...i guess ill have to replace it...thanks for the help
would a pair of o2 sims cure that issue
