HP Tuners .bin file Repository -- Search for bins , upload your own bins!
#143
having some issues w/the server ... it's back up now but my RAID5 keeps dropping... seems one of the drives is going south... i hve it alive now, but not sure how long before it kills itself again... should have a replacement drive tuesday
#145
1 Post
Horist,
I can't download the #14 tune when searching for 2002, chevy, camaro, LS1, A4
What is wrong? All others will download. My laptop died and I am trying to get my tune on to my new laptop. I want to compare it to the tune currently in the car.
Thanks
Jon
Thanks
Jon
#146
if you right click on the file and go to properties, can you post up the file name? (The file name is my key into the database to see what's happening)
#150
hmmm... that's odd... I'll investigate to see what's going on... the URL is generated dynamically from a database of the file names (the file names are random generated numbers w/the time of day and the date as the seed number) ... I'll have to check my code to see why it's allowing incorrect URLs to appear...
I'll be loading hte latest uploaded tunes to the repository tonight as well
#153
I'll approve everything tonight
The LS2 files will be in .hpt format (they'll still unzip as .bin but are actually .hpt) so will need HPT 2.0 to read
#155
I could use a bin for:
Stock LQ9 Bottom end
TSP LS6 64cc heads (the $899 ones) I'm guessing compression is around 10.8 - 10.9 so almost stock LS2.
Magic Stick 3
Granitelli 85mm MAF
Stock LQ9 TB using Drive by Wire
46# injectors
700r4 Transmission
3.7 gears
This is in a 2500lb datsun 240z. Once all the parts arrive I have a full day on the dyno.
Magic Stick 3
Granitelli 85mm MAF
46# injectors
700r4 Transmission
3.7 gears
