Reading timing on efilive
Old 07-09-2004, 03:44 PM
J 98ta's Avatar
Default Reading timing on efilive
Quick question to be sure I am reading it correctly. This is for v5. I would assume v6 is same ? I just got the key this morning.
If I am logging timing, and knock, I need to subtract the knock from the reported timing to get what the car is actually seeing ?
Thanks !
'J
Old 07-09-2004, 03:54 PM
Bink's Avatar
The reported Timing is the actual timing delivered via the PCM. If Knock Retard occurs then the scanned KR value will increase and you'll see a decrease in your timing values for those frames. It's pretty neat to watch - I think so anyway. Modern electronics are amazing. )
