With a big cam If you arent.................
Supposed to use your Trims to tune Part throttle driving how do you expect the trims to 0 out when transitioning to WOT
I havent even gotten around to WOT tuning yet. I am still trying to dial in my PT driving and wanted to know what I could use to get it under control (besides a WB) if i couldnt use the LTRIMs.
HumpinSS, I'm not clear, why do you think you CAN'T adjust your LTFTs, to just under zero, with a big cam?
Originally Posted by P Mack
The reasoning is the overlap will cause a lot of unburned air/fuel in the exhaust which will throw off your o2 readings at idle. So even if you got your ltrims to zero at idle, you'd probably be pretty rich.
joel
