Random KR. (screen capture)
Does anyone know why I'd pick up random KR like this? As far as I know I was just cruising along... you can see that by the throttle position.
The data on the left reflects the moment of peak KR.
Vehicle info in sig...
Random KR is a tough thing to figure out. I have seen 'random' KR events that I have been able to attribute to driving over RR crossings or gravel in the road. But I have also seen them on smooth roads with no obvious explanations.
If you don't see this regularly, I doubt it is anything to worry about.
Thanks guys...
I see a fair number of occurances of small amounts of knock under hard acelleration... This was the largest I saw as long as I can recall.
At times I have a small rapid knock in my steering shaft because it needs to be lubed. Do you think a knock from the steering could be 'heard'?
Otherwise, the whole front end of the truck is tight. I've got a few little custom brackets secureing tranny lines and power steering lines and such.
Originally Posted by marc_w
Thanks guys...
Is it so loose that it could hit your exhaust manifold, or could your manifold be hitting it?
Nah, it's a common thing with the full sized trucks... (luckily)
The shaft is at least two to three pieces - there is a section up by the firewall that's splined and it's allowed to slide to aid in removing the shaft, or maybe so the steering wheel doesn't take you out in a front-end colision. If the splines are dry, it's felt while turning as a very light knocking feeling in the wheel.
