knock senor problems
Does any body know what is going on with my car. I put a ls6 intake on and now it throws P0327 and P0332 codes. The car only retards the timing when WOT, but the MIL goes off when I am just taking off and not getting on the gas.
Thanks
Thanks
It sounds like you may have crushed the knock sensor wire installing the intake. If it was just one code, the wire is okay and the KS is bad. The other possibility is that the KS pin(s) on the pcm is/are fried. My money goes on the wire though. I don't know how careful you were, but the wire has to be routed to the left, but not under where the intake seats.
