LS1edit VE tables vs HPtuners VE tables???
Hey guys I finally found somebody that has a cam similar to mine and they were kind enough copy there VE to Excel for me so that I can try it out. Only problem is that they were using LS1edit, and I have HPTuners. I would like to try them out for a baseline and adjust from there. My question; is the LS1eidt Ve and the HP VE based off the same numbers or will I have to do some kind of conversion to the edit numbers 1st? It seems like I read somewhere that they do not show up the same. Edit shows a true VE number and HPT is given as a percent....Any insite to a conversion?
Matt
Matt
