fuel trims vs. timing for closed loop
Old 08-14-2004, 03:28 PM
patSS/00's Avatar
Default fuel trims vs. timing for closed loop
Does timing change depending on LTFT value? I.e. if everything else (MAF, etc.) stayed the same, would timing change for different LTFT?
Old 08-14-2004, 04:21 PM
TT_Vert's Avatar
timing isnt based on fuel trims rather g/cyl, ECT, IAT, OPEN or CLOSED loop, high/low octane etc. Fuel trims just tell you how far from stoich the ECM is and what the computer is doing to compensate.
Dave
