Stock MAF vs. Cal'd 85mm
With the "calibrated" (resistored) 85mm for Pace would I be better off keeping the stock cal's or would it be beneficial to remove the resistor mod and load Vette or LQ9 values.....in addition are the LS1Edit values the same as the HPTuners values when it comes to the MAF tables??
Moderator
Posted here under my username some while back.
The MAF base unit is a known quantity, the effects
of the "calibration" are not (challenge SLP or Pace
to produce a valid LS-1 MAF table, and see).
