Need help fast my WOT run was 13.9.1 A/F ratio
Need help fast my WOT run without Nitrous was 13.9.1 A/F ratio
What should I adjust my A/F PE table to in order to bring me down to where I should be? My current PE table looks like this.
1.21 1.21 1.21 1.21 1.21 1.21 1.21 1.21 1.21 1.21 1.21 1.21 1.21 1.21 1.21 1.21 1.21 1.21 1.21
My mods are in signature
To Bring your A/F Ratio down to the 13 to 1 area Multi your table by about 110% To bring it up to 1.331 across the board. You want the car to be a little on the leaner side in the lower rpms to give you a good Torque curve. I would have the table from 0 to 2400 5% leaner than from 2400 to max rpm.
Good luck
Clint
Good luck
Clint
