so what else can the GEN7 do?
Can it run biger injectors 96lb?
Can it change timing for NOS when the nitrous is spraying or only what the switch is on!
I heard you have to cut a 2" hole in the firewall for the harness to go in the car?
Can the factory PCM be removed?
Anyway it can control boost for my turbos?
Thanks I bought it and it will be on my car in a few weeks but sad to say I don't know **** about it!
LS1Tech Co-Founder
YES, it can run low impedance injectors
DUNNO
I run a FAST but we just used the factory hole.
I have a FAST and removed mine, it's similar.
DUNNO
DUNNO
DUNNO
thanks I did buy the wb O2 sensor! And I just told the shop to get 80lb injectors! As I talked to the tuner we are going to do a salf 600hp on turbos then spray 200hp! the injectors will let me and boost when ever i want without a retune!
