DTC P0106 H help!
Old 08-24-2004, 12:06 PM
RUF SS's Avatar
Default DTC P0106 H help!
Hi everyone,
My car ( 2002 ZO6 ) got an SES light, when i checked it, it turned out to be P0106
Does anyonw know what that mean? and what is the solution to this problem.
Thank in advance.
Old 08-24-2004, 12:48 PM
RUF SS's Avatar
Ttttt
Old 08-24-2004, 02:10 PM
RUF SS's Avatar
tttttttt
Old 08-24-2004, 02:18 PM
horist's Avatar
Manifold Absolute Pressure System Performance
Strange that you're seeing that in a 98 PCM... maybe it's turned on there too?
When my car was a 2000 OS it had P0106 disabled by default from GM... but when I upgraded to a 2002 OS it was not turned off by default and I was setting it ...
I think something to do w/the bigger cams sets this code... my buddy w/a tuned 2002 has this code disabled (he has a TSP cam)
edit just saw it was for a z06 .. do you have a cam in it? or is it stock? if it's got a cam then prolly just need the code turned off... if it's stock sounds like the most likely cause is a vacuum leak... has the intake manifold been off recently?
Old 08-25-2004, 03:25 PM
RUF SS's Avatar
Thanks! To be honest, I have no idea if it has a cam! I just got it!
Dose this code hurts performance?
Old 08-27-2004, 07:34 PM
RUF SS's Avatar
Guys, please help! My cars Idels like if it has a cam! I am not sure if it does, but the dyno says stack cam! 345 rwhp! And some times it nealy shuts off when I start it!
