wideband users: which do you have and how do you like it?
i need one, im leaning towards the zeitronics unit mainly because its only $280, and it can be used with hptuners (as soon as wideband support becomes available).
http://www.zeitronix.com/Products/zt2/zt2.htm
i'd like to hear from different people your thoughts on the ones you use, thanks
Originally Posted by GM Muscle
I'm really happy with my LM-1 set up. Although, I've never used anything else so I really can't compare it to any others.
http://www.techedge.com.au/vehicle/wbo2/
I've had no issues with mine and I haven't heard a bad word about them.
Has anyone used the LM-1's clamp on holder and bung? What were the variances between the two options? How feasible would it be to use the clamp instead of a bung and swap the unit back and forth between 2 cars?
Just had my PLX Devices come in the mail. I'll wire it up in the next couple of weeks. I choose it over zietronics 'cause the analog wideband output is linear.
Not knowing how HP tuners intends to correlate Volts to A/F ratio, having a non-linear output may be an issue. I am assuming the HPT software will need to be calibrated for the analog input. Perhaps I assume wrong.... anyone know? HPT got something to add?
Speaking of which, when is the HPT cable shipping?
i might have to wait for HPTuners to release the new cable/software before i make my decision, i want to be absolutely sure that the wideband i buy will work with the new version
12 Second Truck Club
Originally Posted by Turo
waht is the difference between linear and non?
A linear output converts the a/f into voltage using a constant ratio. For PLX 0V = 10 A/F, 2.35V = 14.7A/F, and 5V = 20A/F. All points between can be determined using a linear expression A/F=2*V+10 .... easy
A non linear output will require an exponential equation at best or a calibration table at worst. More work
My guess is that PLX converts from digital wherease Zietronix keeps it analog.
Tech Addict
The LM1 has worked well for me. Sample log...WOT 3rd.
This made my tuning easy from far away, like sending info to Diablo Sport. Took no time and paid for itself from going to the dyno.
Time(sec)AFR RPM
0 14.32 1720
0.082 14.44 1740
0.164 15.16 1730
0.246 16.14 1860
0.328 14.24 1760
0.41 12.94 1870
0.492 12.33 1860
0.573 12.22 1910
0.655 12.02 1940
0.737 11.94 1950
0.819 11.91 2110
0.901 11.83 2030
0.983 11.72 2050
1.065 11.7 2090
1.147 11.67 2100
1.229 11.67 2170
1.311 11.7 2170
1.393 11.66 2200
1.475 11.54 2250
1.556 11.45 2270
1.638 11.41 2310
1.72 11.51 2340
1.802 11.66 2870
1.884 11.6 2410
1.966 11.57 2450
2.048 11.73 2460
2.13 11.47 2530
2.212 11.39 2560
2.294 11.55 2600
2.376 11.58 2610
2.458 11.51 2680
2.54 11.55 2700
2.621 11.5 2750
2.703 11.39 2780
2.785 11.48 2820
2.867 11.44 2850
2.949 11.3 2890
3.031 11.38 2940
3.113 11.42 2970
3.195 11.57 3010
3.277 11.38 3040
3.359 11.39 3090
3.441 11.32 3120
3.523 11.41 3150
3.604 11.47 3200
3.686 11.41 3250
3.768 11.25 3270
3.85 11.13 3320
3.932 11.47 3370
4.014 11.35 3400
4.096 11.44 3450
4.178 11.38 3490
4.26 11.51 3520
4.342 11.5 3570
4.424 11.42 3610
4.506 11.32 3650
4.588 11.44 3710
4.669 11.39 3740
4.751 11.39 3780
4.833 11.44 3810
4.915 11.48 3880
4.997 11.5 3940
5.079 11.48 4000
5.161 11.61 3990
5.243 11.7 4050
5.325 11.63 4100
5.407 11.39 4140
5.489 11.38 4200
5.571 11.16 4230
5.652 11.19 4290
5.734 11.19 4320
5.816 11.1 4370
5.898 11.25 4400
5.98 11.36 4460
6.062 11.26 4470
6.144 11.29 4530
6.226 11.29 4590
6.308 11.3 4640
6.39 11.17 4660
6.472 11.05 4730
6.554 11.04 4770
6.636 11.11 4780
6.717 11.04 4840
6.799 11.01 4870
6.881 11.07 4920
6.963 11.13 4990
7.045 11.17 5030
7.127 11.27 5120
7.209 11.41 5160
7.291 11.36 5180
7.373 11.45 5190
7.455 11.29 5250
7.537 11.48 5280
7.619 11.51 5290
7.7 11.64 5350
7.782 11.5 5430
7.864 11.51 5420
7.946 11.54 5470
8.028 11.58 5510
8.11 11.52 5560
8.192 11.55 5610
8.274 11.54 5650
8.356 11.41 5680
8.438 11.75 5730
8.52 11.61 5770
8.602 11.7 5800
8.684 11.69 5350
8.765 11.83 5890
8.847 11.54 5660
8.929 13.1 5400
9.011 12.95 5240
9.093 12.57 5020
9.175 15.39 4800
9.257 20.08 4580
9.339 22.39 4390
9.421 22.39 4200
9.503 22.39 4080
9.585 22.39 3960
9.667 19.12 3870
9.748 15.92 3750
9.83 14.2 3650
9.912 13.35 3580
Time(sec)AFR RPM
0 14.32 1720
0.082 14.44 1740
0.164 15.16 1730
0.246 16.14 1860
0.328 14.24 1760
0.41 12.94 1870
0.492 12.33 1860
0.573 12.22 1910
0.655 12.02 1940
0.737 11.94 1950
0.819 11.91 2110
0.901 11.83 2030
0.983 11.72 2050
1.065 11.7 2090
1.147 11.67 2100
1.229 11.67 2170
1.311 11.7 2170
1.393 11.66 2200
1.475 11.54 2250
1.556 11.45 2270
1.638 11.41 2310
1.72 11.51 2340
1.802 11.66 2870
1.884 11.6 2410
1.966 11.57 2450
2.048 11.73 2460
2.13 11.47 2530
2.212 11.39 2560
2.294 11.55 2600
2.376 11.58 2610
2.458 11.51 2680
2.54 11.55 2700
2.621 11.5 2750
2.703 11.39 2780
2.785 11.48 2820
2.867 11.44 2850
2.949 11.3 2890
3.031 11.38 2940
3.113 11.42 2970
3.195 11.57 3010
3.277 11.38 3040
3.359 11.39 3090
3.441 11.32 3120
3.523 11.41 3150
3.604 11.47 3200
3.686 11.41 3250
3.768 11.25 3270
3.85 11.13 3320
3.932 11.47 3370
4.014 11.35 3400
4.096 11.44 3450
4.178 11.38 3490
4.26 11.51 3520
4.342 11.5 3570
4.424 11.42 3610
4.506 11.32 3650
4.588 11.44 3710
4.669 11.39 3740
4.751 11.39 3780
4.833 11.44 3810
4.915 11.48 3880
4.997 11.5 3940
5.079 11.48 4000
5.161 11.61 3990
5.243 11.7 4050
5.325 11.63 4100
5.407 11.39 4140
5.489 11.38 4200
5.571 11.16 4230
5.652 11.19 4290
5.734 11.19 4320
5.816 11.1 4370
5.898 11.25 4400
5.98 11.36 4460
6.062 11.26 4470
6.144 11.29 4530
6.226 11.29 4590
6.308 11.3 4640
6.39 11.17 4660
6.472 11.05 4730
6.554 11.04 4770
6.636 11.11 4780
6.717 11.04 4840
6.799 11.01 4870
6.881 11.07 4920
6.963 11.13 4990
7.045 11.17 5030
7.127 11.27 5120
7.209 11.41 5160
7.291 11.36 5180
7.373 11.45 5190
7.455 11.29 5250
7.537 11.48 5280
7.619 11.51 5290
7.7 11.64 5350
7.782 11.5 5430
7.864 11.51 5420
7.946 11.54 5470
8.028 11.58 5510
8.11 11.52 5560
8.192 11.55 5610
8.274 11.54 5650
8.356 11.41 5680
8.438 11.75 5730
8.52 11.61 5770
8.602 11.7 5800
8.684 11.69 5350
8.765 11.83 5890
8.847 11.54 5660
8.929 13.1 5400
9.011 12.95 5240
9.093 12.57 5020
9.175 15.39 4800
9.257 20.08 4580
9.339 22.39 4390
9.421 22.39 4200
9.503 22.39 4080
9.585 22.39 3960
9.667 19.12 3870
9.748 15.92 3750
9.83 14.2 3650
9.912 13.35 3580
i have a lamdaboy NTK based unit (bought it years ago) the ntk sensors react faster and are more accurate in very rich conditions. Also cost a bit more FJO used to make NTK based sensors. They are more prone to exhaust pulse than the bosch units.
It has 0-1V o2 compatible mode and 1-0V mode and 0-5V mode (one was an option i think). Worked great but the wiring on the sensor to db9 left something to be desired.
we've got access to the lm-1 with rpm pickup, its not bad, just slower sampling and more features and uses the cheapest sensors which we've burnt out one somehow already.
Very happy with the Zeitronix unit
Hey all,
I just wanted to post and brag about the zeitronix A/F set up I just received and used. http://www.zeitronix.com/index.html -- Zt-2 Wideband Air/Fuel Ratio Meter
I am a real customer, not someone from the company pushing their product (check my other posts..). Anyway, I already had the laptop, so for about $300 less than the comparable Innovative set up I was able to measure, data log, and add custom user inputs (like RPM, boost, exhaust temps, etc). I am really impressed with this set up. ---- and now I no longer have to rely on the dyno A/F to effectively tune!! (At $100.00 per session!!). Totally psyched!
The readings seem accurate compared to a recent dyno session.
I have been using the Innovate Motorsports LC-1 and has worked perfectly. It has made tuning a breeze and with no guesswork. I am using the linear output connected to the HP Tuner's EIO Interface. I have been using it for a month and have no iseeues with it. It was easy to install and is $199. There are a couple of gauges that will work if you want a constant readout whether using a laptop or not.
LM-1 here too. Seems real accurate, and it has gotten the job done. Also kudos to Klaus on the Innovate forum for his great help in getting the most out of the product.
