cam installed, accessory problem
Had my cam installed, car LS1 Edit tuned, by a sponsor. Now when I turn my A/C or Defrost on the car hesitates, and sometimes I hear a squeaking noise coming from the fan. Sometimes the fan shuts off altogether. Anybody ahve similar issues with install/tuning? Should I take it back to the tuner or to the dealer (it's under warranty). Thanks
Originally Posted by DD966
I'd rather not drill a hole in the throttle plate. It idles fine without the accessories on.
The issue you are describing about the A/C causing problems with your idle is tuning related. I initially had this problem with my cam with the stock tune and corrected it with HP Tuners. It sounds like they may have only tuned it with the A/C off or on the dyno in which is usually is always off.
