Car Wont Down Shift At WOT At Mid RPM After Trex Install
Old 09-02-2004, 03:13 AM
2MuchRiceMakesMeSick's Avatar
Default Car Wont Down Shift At WOT At Mid RPM After Trex Install
After I installed a trex, 90mm lsx, pully the car sometimes will not down shift at wot. If I am in lower rpm > 2000 it downshifts and HAULS *** but if i am above 2k the engine just boggs down and stays in the same gear. This never happend when I had the stock cam in. The only thing that I have changed in my tune is the 5 things below, all other stuff is default. Do I need to change my shift points because of a cam? What would cause this?
1. Idle Limiters --> Idle Speed: 850
2. Idle Limiters --> Idle Air In Gear: All points 60C and up to 8.6
3. Fuel --> Main VE Table: Multiply column 400 rpm by .53. Multiply column 800 by .69. Multiply column 1200 by .80 Multiply column 1600 by .95.
4. Ignition --> High Octane Table: Add 2 deg to all points 400 to 1000 RPM, .08 to .32 g/sec
5. Disabled misfire detection 141/142
Old 09-06-2004, 09:59 PM
Someones gotta have some ideas on this. I have tried everything I know to try on this. I changed my shift points and that helped a little. Can someone post their shift points in an A4 that has already been tuned?
Old 09-07-2004, 09:56 AM
John_D.'s Avatar
Some shift table info in this thread:
https://ls1tech.com/forums/pcm-diagnostics-tuning/211850-shifts-early-into-od-can-tuning-fix.html
Old 09-07-2004, 11:55 PM
I copied that table and it still does the same thing. Any one have any other ideas?
Old 09-08-2004, 06:09 PM
MADCOW's Avatar
I just did h/c on my car. I'm running a 231/237 cam. Ever since I've had the same problem. I think it may be from a throttle position sensor insufficiant ac code thats being thrown. Are you throwing any codes? good luck!
Old 09-09-2004, 05:47 PM
I got that same code. But I have not gotten it in a while. Have you tried replacing your tps? Is there a fix for it? Anyone?
Old 09-09-2004, 06:28 PM
V-10 Killer's Avatar
I had that problem with doing my 231/237 cam too.
I wound up having to raise my P0121 settings on the Engine Diagnostics Tab, from 55 and 65, to 75 and 85.
That single step cured it
Old 09-09-2004, 07:27 PM
I wound up having to lower my P0121 settings on the Engine Diagnostics Tab, from 55 and 65, to 75 and 85.
Thanks, Ill go try that. Did you have problems with your engine bogging down also? Does this have any other affects in the car?
Old 09-09-2004, 08:29 PM
I don't think it does directly.
I had some bogging issues. But once I got the Throttle Blade positioned right, and the Idle and Running airflow right, it got better.
Old 09-12-2004, 12:16 AM
I changed that one value and it threw off my ltrims and the car surges alot, but my tranny downshifts every time now. I just need to get my A/F ratio back on track. Thanks for all the help. This fourm kicks ***!
Old 09-13-2004, 05:56 PM
GrannySShifting's Avatar
yeah trasn shifts off tps, and big no vacuum having cams wig out the values it expectign to see at certain TPS. Sometimes itll make them no shift or lose a gear Ive seen also
Old 09-13-2004, 06:01 PM
Well that seemed to clear up the downshifting issue. Can someone explain was P0121 means exactly and how it might affect the preformance?
Old 09-13-2004, 06:27 PM
Lady Redhawk's Avatar
Location: sojourning....looking for my city whose builder and maker is God.
The larger cam is raising your Manifold Absolute Pressure at idle. When the pcm sees the higher MAP it is expecting the throttle to be at a higher % than it is, so it throws a code which can effect how it shifts. The pcm runs the test for this code between 55 and 65 MAP, raising the values as described to run the test between 75 and 85 MAP fixes the trouble.
Old 09-17-2004, 01:15 AM
Well that cleared up the issue now the car is running great. Thanks alot to everyone that helped. Now I just have to get that surge to go away at 1100 rpm....dam trex.
Old 01-25-2005, 08:25 PM
Q
Q's Avatar
So you finally got that Trex acting civilized huh? do you think the high idle is going to cure the surge? My idle is at 1000rpm and I used the NoGo guide to start. I went to 9.2 on the IAC for surging....even thought it's still surging. I'll probably use your specs and with an 1075 idle to see if she's better at idle and on the stop.
Old 01-26-2005, 12:30 PM
Since then I have been able to work my idle down to 850 when warm. With the dual street pro electric cutouts after the headers with dumps. It sounds mean
Old 01-26-2005, 12:41 PM
Q
Q's Avatar
check your PM's
