K.p.h. Default
K.p.h. Default
On a U.S. spec car the speedometer will always default to M.P.H., for instance if you dis- connect the battery then re- connect it again, it will always default to M.P.H. I want it to default to K.P.H. I am hoping this is a programmable possibility, I have had many comments on this issue but no precise definate solutions, does any one know for sure how to achieve this?
RON.
RON.
K.P.H. default
Hi my name is RON and I am in Australia. I believe the B.C.M. controls this function but can not confirm 100% If so then I thought it would be a programming issue. Canadian spec cars will default to K.P.H. so it must have been programmed in that format either in the B.C.M. or the speedometer, I think more likely in the B.C.M. But getting factual evidence and a sure fire way of achieving this goal is what I am after. Thanks for your responce, I will resolve this issue somehow.
RON.
RON.
