Data logging a wb/autotap?
If I setup a excel spread sheet and log the wb vs rpm.Then I data log the map/pe tables/ve tables/timing/kr etc via edit and overlay this info to my spreadsheet will it be accurate or will it be the data be off sync?
With the spreadsheet I can overlay both data logs and have a pretty good amount of info in real time over a broad rpm and I wont have to reference all kinds of wiring.
I'll just log one (Edit) vs other (WB)
Overlay the software via excel spread sheet?
There is an easier way to do this in access
YOu would import both csv files into two separate tables and run a query to join the tables based on a ts. All the matching ts will be paired off and no sync issues.
select * from table1 a join table2 b where a.ts=b.ts
The resltant table can then be exported back to a csv to be viewed in excel or you can do all you averaging right there in access
Make sure both timestamps have the same resolution n the ms or this wont work
