How much power can be gained by going from
Old 09-15-2004, 09:28 AM
HumpinSS's Avatar
Default How much power can be gained by going from
a 12:1 AFR to 13:1 is there some type of set forumla or norm to figure this out
Old 09-15-2004, 10:03 AM
MECHAM's Avatar
no...
as there are too many variables to consider (cam, heads, stock engine, flow, fuel, gas, FI, effeciency range, etc...etc...)
of course i could be wrong...but maybe one of the smart people here will verify what i said
Old 09-15-2004, 11:37 AM
Moderator
jimmyblue's Avatar
I think the best answer might come from the Dyno section,
looking for same-car, varying-mixture results. But last time
I asked I don't think there was any data. Also you would
want to have your spark adjusted for the mixture at hand,
it's not a single-variable problem even when you limit it
to tune settings.
Old 09-15-2004, 02:34 PM
TT_Vert's Avatar
io gained 2 tenths and about 2 mph in the 1/8th
dave
