Hp tuner -- How to delete this - LS1TECH
PCM Diagnostics & Tuning HP Tuners | Diablo | Pantera EFI
Thread Tools Search this Thread
Old 09-19-2004, 12:56 AM   #1
Fierce-LS1's Avatar
Default Hp tuner -- How to delete this
Anyone know how to delete the reverse lockout signal from the PCM ?
Fierce-LS1 is offline   Reply With Quote
Old 09-19-2004, 01:07 AM   #2
why would you want to do that
HumpinSS is offline   Reply With Quote
Old 09-19-2004, 01:26 AM   #3
Fierce-LS1's Avatar
4l60E was converted to T56. Have no clue where to tap into the PCM for the reverse lockout and I'm tired of looking at this damn SES light
Old 09-19-2004, 04:08 AM   #4
horist's Avatar
http://www.ls2.com/boggs/torques/00pinpcm.htm
pin 44 on RED connector seems to be it... I believe the connections for 99-02 F-Bodies are the same... maybe someone has an 02 pinout to verify though?
horist is offline   Reply With Quote
Old 09-19-2004, 09:17 AM   #5
Closed ex-Sponsor Account
you could just disable the code, in the dtc section? it says pin 44 on the computer is for reverse lock out, just go get a connecter from gm for 13 dollars, then run one end of the wire to a 12 volt ignition wire, then the other to pin 44, you will have to just move a wire to that spot, you can use any from that 4l60e harness you are not using anymore,
waucanda, i picked up my tranny from there, a place called hpa ? i got sooo lost trying to find that town... i thought it was right in chicago, then ended up i dont even know where... some nice cars in there though, even the only mustang i would ever drive, that ls1 f1 blower mustang..
wait4me is offline   Reply With Quote
Old 09-19-2004, 11:37 AM   #6
I wish I could change when it engages.. I hat not being able to go to reverse on a slow roll..
ataylors is offline   Reply With Quote
Old 09-19-2004, 12:11 PM   #7
Fierce-LS1's Avatar
thanks for the help guys
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
