Cam sencor bad - now what?
My mechanic tells me my cam sensor is bad!
I did not know there was a cam sensor in Gen 3 engines. Where is this? I did not see any sensor when I changed the cam 1.5 years ago. I thought the only internal sensors were; 1. knock sensors under the valley cover and , 2. reluctor wheel sensor?
Any thoughts?
Thanks...
Any thoughts?
Thanks...
not sure if you can get it at a parts store
here's the info from my parts manual:
AC Delco 213-363 99-02 LS1 F-Car P/N: 12561211
Description: Sensor, CM/SHF POSN (INCLS #106) (106 is a seal)
40 bux on sdpc2000.com
I hope it fixes the tech problem too! These sensors going bad casue major headaches - can;t GM do a better job
GM cars really suck; I won;t be buying any more -that is a fact!
