I have a HP Tuner question about Cruise control effect
well now my IAC is pretty close to stock now,If I let off the gas my car seems to continue to cruise with cruise control off?It is worse from some MPH than other mph ,mostly in the 1400 to 2000 RPM range.What do I need to look at,Throttle Cracker?
Thanks...
Thanks...
Originally Posted by P Mack
Does it go away when you come to a complete stop? Does it hang for a second before dropping or just hang at the rpm indefinately? Mine was hanging at the rpm forever until I came to a complete stop, and the throttle cracker fixed it.
Yeah I cut them all in half. Also there's a block of numbers from 1600 to 2200 rpm from 24 mph on up that is higher than all the rest. I am thinking that is to keep your rpms from dropping too much when shifting, but you might want to cut down on those too since that's the range that's causing you problems.
