What changes for larger injectors?
Old 10-12-2004, 09:59 PM
JimMueller's Avatar
Default What changes for larger injectors?
I've got the stock '98 injectors. The next step up are the 30lb SVO's, right? Regardless, what changes will I need to make in my calibration?
Do I just need a matching IFR table, then alter it for negative fuel trims again? Will everything else balance out by itself?
Old 10-12-2004, 10:03 PM
AnthonyR's Avatar
going to have to adjust your ifr for ltrims and most likely your pe vs. rpm table for wot
