Killed PCM! Will edit work with reflashed pcm
While flashing my PCM, my computer battery died. You guessed it fryed the pcm. I can get a repalcement pcm reflashed with vin and stock file. Will my edit cable work or do I have to send it in to have it set up for the new pcm ?
Originally Posted by edg1957
As log as the VIN stays the same you'll be fine. Good luck!
Ed
Ed
Sounds like I am out of $325 at least then to get back up and running...Sounds like I'm better of buying HP tuners. Can anyone confirm that hp tuners can recover the files in my pcm?
As far as a dealer re-flash, I would call first...some dealerships have an off vehicle machine that will reflash it back to factory spec without needing the vehicle there. The only thing is, you get the latest GM program which in some cases will make aftermarket tuners like Hypertech not work. There is a way....no need to buy a new pcm.
Thanks to all the guys that responded with offers to help. I ended up shipping my pcm to Carputing to see if they could restore my pcm. Fortunately they were able to get it working and even re-install the tuning file that I sent to them. I should have it back by tomorrow. I have to give them credit - 1 day repair turnaround is pretty damn good. Gordy, I will still probably give you a call to get your guy's name in case this ever happens again. I will definitely keep a power inverter in the car in the future for reflashes and scanning on the road.
