View Poll Results: Which of these describes how you tuned idle air, and your surging (or lack thereof)?
Set screw, no surging.
9
3.54%
Set screw, have surging.
12
4.72%
Drill mod, no surging.
9
3.54%
Drill mod, have surging.
14
5.51%
PCM tuning, no surging.
109
42.91%
PCM tuning, have surging.
101
39.76%
Voters: 254. You may not vote on this poll
Surging Poll after Cam; please vote if you don't have surging problems too!
Old 11-12-2004, 01:59 PM
Another_User's Avatar
Default Surging Poll after Cam; please vote if you don't have surging problems too!
Please vote based on how you increased airflow and if you have a surging problem at light throttle and low rpms.
Old 11-12-2004, 05:10 PM
monodax's Avatar
This is not on your list but when I upgraded my rear end gear from a 3.42 to a 4.10 it made a huge difference in the surging and bucking @ low RPM's. It is barely noticable now compared to when I just tuned it using the stock gearing. I have a T-Rex cam but I would assume this applies to other cams as well but 4.10's where recommended from Thunder Racing on their site. It may be something you might want to look into if you haven't upgraded already.
Old 11-12-2004, 05:57 PM
Ragtop 99's Avatar
I found that a combination of tuning and a little more air via the set screw helped with surging.
Old 11-12-2004, 06:17 PM
luv2spd's Avatar
What if you open the tb blade to get iacs down, but you still have surging? My main question is on the fuel side of it. Is the surging/bucking an indication of too rich or too lean? What if you get the ltfts at -3 to 0 via ve table and still have surging?
Old 11-12-2004, 06:54 PM
P Mack's Avatar
Set Screw, mafless ve tuning, and ve smoothing => no surging or bucking. I only have a 222/222 112 lsa cam though.
Old 11-12-2004, 07:13 PM
I don't know. I am hoping we can see some sort of pattern. I think the only pattern I see is that people who did the "drill mod" aren't responding to the poll. Crap.
Old 11-13-2004, 12:21 AM
DrkPhx's Avatar
Angry
Set scew = surging, PCM tuning = surging, Drill mod = surging. Surging =
Old 11-13-2004, 12:49 AM
SMOKIN01TA's Avatar
yea, im with him, but its worth it.
Old 08-24-2005, 06:46 PM
TAQuickness's Avatar
I've done them all and have no surging at idle... However, I do still get a bit at 1500-1800 rpm....
Old 08-24-2005, 07:20 PM
RedHardSupra's Avatar
idle screw, reset tps sensor, perfect VE, perfect RAF, no surging on strokers with 240+ duration cams
Old 08-24-2005, 08:05 PM
Blacker's Avatar
I did the drill mod and still had surging. I finally nailed it down with tuning. The IAC Effective position was key.
Old 08-24-2005, 10:02 PM
WS6FirebirdTA00's Avatar
drill mod does nothing more than the set screw can. my set screw at stock position runs fine. i get no bucking with 3.42's at 900-1000 rpm anymore. i cant even make the car buck or stall or want to run liek ****
Old 08-25-2005, 12:02 AM
ninobrn99's Avatar
show off :jk:
f10 114, i think janzter did the drill mod on the TB blade, set screw adjusted and tuning and still surging....stock cam goes back in this weekend
Old 08-25-2005, 09:33 AM
Larry's Avatar
Listen to what RedHardSupra has to say. I used his spread sheet to correct my RAF's and it eliminated my surging. Thanks Marcin!
Old 08-25-2005, 09:48 AM
ninobrn99's Avatar
Marcin is the man!! Tuners comes in today!!!!! im gonna try the RAF spreadsheet out today if i get a chance.
Nino
Old 08-25-2005, 10:53 AM
Rick@Synergy's Avatar
Timing is your friend right here and any driving conditions. People still dont get how much timing they can put back into their PCM table after a cam change. Its all about making a T-rex drive like a 220 cam.
Old 08-25-2005, 11:19 AM
you can add timing if you are rich at idle, but if you lean it out like it should be you can run low amounts of timing. how much timing do you run at idle?
Old 08-25-2005, 11:29 AM
What are your cam specs.?
Rick
Old 08-25-2005, 11:48 AM
230/232 and i use the same technique on a 237/242 to get its idle good, unless going so much higher will make it better, but i just think it would cause some knock on takeoff and when reving
Old 08-25-2005, 01:58 PM
Nope, timing will not cause knock with a cam like that. Are you using HPtuners? If so PM me or email me and I can send you a timing table that might work for you.
Rick
Quick Reply: Surging Poll after Cam; please vote if you don't have surging problems too!
