Who is running Z06 VE table?
Old 11-19-2004, 10:02 PM
John02SS's Avatar
Default Who is running Z06 VE table?
Wanted to check into this and see how many guys are running it and the change it made on the car from the stock VE tables. What kinda result did you get? Been playing with the LTrims and I see some have had good luck with the stock IFR, slightly adjust MAF for descreened MAF, and Z06 VE table. Any input is appreciated.
John
Old 11-19-2004, 11:16 PM
John02SS's Avatar
what spec cam are you running? I'm about to put in the Z06 file with the 400, 800, and 1200 areas reduced for the cam at startup.
Old 11-19-2004, 11:19 PM
TT_Vert's Avatar
stock cam.
Old 11-19-2004, 11:28 PM
WS6snake-eater's Avatar
Hey john you will not need to make real drastic adjustment when going with the z06 cam. Just copy the z06 VE table that is listed in the thread bellow this one and you will be good to go.
Old 11-20-2004, 09:01 AM
Another_User's Avatar
I am using a modified Z06 table. It is still way too rich for most cams. Low rpm/kpa is rich, higher rpm/kpa is lean. Won't require much for a MAF tune on a Z06 cam.
Old 11-20-2004, 09:26 AM
John02SS's Avatar
I running a TR224/112. It's a little rich low so I tweaked it for that. Thanks for the input guys!
Old 11-20-2004, 08:30 PM
AgentOrange's Avatar
hey can you post a stock ZO6 table, perferrably a '02 table we have a little confusion here:
https://ls1tech.com/forums/showthrea...=240672&page=2
