GM Engine Managment Threshold
Old 11-21-2004, 09:54 PM
finiata's Avatar
Default GM Engine Managment Threshold
At what point is it aftermarket engine managment needed. If, when I build my 427 stroker LS1 twin turbo can I tune it well with the correct software? I will be using the truck heads to lower the compresion & a sleeved block.
mike
Old 11-21-2004, 09:59 PM
LS1Tech Sponsor
hellbents10's Avatar
Well you are going to run out of the limits of the MAf and MAP. MAP wouldn't be a big deal but the MAF will quickly max out leaving you with the PE table. This is Ok but like a carb. when its cold it will be lean and when its warm it will be rich. I would reccomend aftermarket like big stuff3.
Old 11-21-2004, 10:12 PM
pkincy's Avatar
There are a fair number of boosted low 9 sec LS1s with stock pcms. They truly are very versatile.
Check the acceleronics web page for a way to run the bigger injectors, but that seems to be the only trick.
Perry
Old 11-21-2004, 10:43 PM
LS1Tech Sponsor
Oh yes you can definatly go fast and make almost any power you want it is sorta a bitch to mess with the baind aid type tuning you ahve to do w/o a 3 bar and running out of MAF so fast. Then agian there is ways to run dual MAF's. I am thinking of doing this.
Old 11-22-2004, 08:28 PM
LS1TECH Sponsor
JeremyF's Avatar
I believe that you can manage that combo with the GMECM. If you have your fuel system covered than let us move on to the maf.
1.) even if the maf is maxed out you can still control the fuel PE vs RPM. not recommended
2.) there are ways of manipulating the maf to control more air, resistors and removing material from the maf so it "thinks" it is getting less air will drastically change the scale for which you can control up to 12000mHz. I would explore this route. you will have to enrichen the lower end of the fuel curve because you will have leaned it for more of a stretch up top. I feel that 800RWHP is very attainable with this setup and can be controlled as GM setup for it to be just slightly altered.
Jeremy Formato
Old 11-22-2004, 08:37 PM
horist's Avatar
well... the fastest LS1 in the country is running stock PCM (Harlan ... 8.29@167 I believe)
The stock PCM is a powerful unit.. w/proper tuning it can support alot of power...
Old 12-03-2004, 01:43 PM
NLang's Avatar
Do tell...(ie:how and what's available)
Old 12-03-2004, 06:19 PM
LS1Tech Sponsor
I am trying to figure this out right now, I will keep updating as I find info. If all goes well I would like to have a set up up and running by the spring.
TJ
Old 12-04-2004, 12:08 AM
Bink's Avatar
I believe the Hp Tuner guys are working on a 2 Bar and 3 Bar setup now. Harlan said he was past the 3 Bar setup already. FWIW.
