Surging and bucking at low rpm and load.
I have been having a problem ever since I installed my AFR's and 224/228 .581"/.588" cam. I have it idling very nicely. When I am idling and give it some throttle and let go more often than not the rpm's will drop to around 400 and then come up to idle. It also happens when driving and I let off the throttle. The other issue I have is if I am creeping along in first or second gear at any rpm under 1500 the car will start to buck and get into an oscillation that gets pretty severe and will not stop until I get the rpm's above 1500. Also if I am on the highway and cruising below 1500 rpm ocassionaly I will feel what seems like the engine bucking slightly, but being in 6th gear it feels like a clunk. I have logged this and see no KR. I have tried messing with every table except for the throttle follower and throttle cracker. I've added and subtracted timing at the low rpms' and loads and have done the same with air and fuel.
While logging this condition the other day I noticed that my MAP was following the oscillation and was varying from 30kpa to 80kpa, but the MAF was sitting at 8.27g/s. I would think that if the MAP was changing that much that there should be a change in the airflow the MAF is monitoring. Also, the MAF never goes below 8.27g/s in my car. I am wondering if the MAF is dirty or if it is on the way out. Any ideas? Am I interpreting this correctly?
Also under all other driving conditions the car is a beast.
Sounds like your DFCO settings are interfering with your CAMs ability to hold dynamic compression at low revs. Try raising your DFCO MAP values by 10kpa (entering and exit) and see how that goes. What I assume could be happening is your PCM thinks your are decelerating and so cuts fuel only to add it again as your MAP values deteriorate.
I am having the exact same problem.
Mine was noticable before, but not intolerable.
I changed to LS-2 intake and 90 LS2 TB thinking I had an airflow problem with the 422 and now it is almost undrivable. Cam is 232 236 @114, stage 3 heads etc
The bucking and idle surging got way worse. Took it to a local shop that fixed start-up idle, but made everything else worse. As soon as I tip into throttle it tries to stall. Letting off throttle at RPM, whether coasting or sitting in the garage, it drops down to approx 500 RPM, up to 1500 RPM, sometimes catches itself after 3 or 4 iterations, sometimes not. I have done numerous idle learns to no avail.
I have single copy LS-1 edit for the car and can email the file if someone out there can help.
thanks
Brad
thanks
Brad
Originally Posted by Ragtop 99
You may be rich at at 1500 rpm. Try reducing your VE at 1600 rpm by 2% (i.e. multiply by 98%) and see if that helps with the surging at 1500 rpm.
I just installed a new cam (TSP235/240) and now I'm getting some pretty severe bucking any time the rpm is below 2000 and at light load. I tried reducing spark timing everywhere below 2000 rpm and that helped a bunch with the bucking, but made the car fall on it's face trying to pull away from a stop. So I had to put about half the spark advance I took out back in.
I've noticed on EFILive that the spark advance bounces up and down a lot when the car is bucking, but I don't know if this is the cause or the effect. Lugging the engine a bit makes the spark advance back off and and bucking nearly stops.
Just looking for some new ideas; ArKay99 did you get this resolved?
I had this happen too, but it's only at no load at exactly 1000 rpm. It's completely unrelated to spark advance cause i made my spark table flat and it still did it, and the spark is pretty much constant when it happens. It also didn't seem to matter whether I was in SD or Maf. I did notice the map oscillating with it, but a little out of phase. By messing with the ve table it seemed like i could either make it stable and die out or unstable and buck worse and worse, but i can't get rid of it completely. I'm gonna try messing with the ve table more in that area as soon as I fix my tranny problems and see if that helps.
Thanks for the reply, P Mack. I think I will try messing with the VE table next as sugested above by Ragtop 99. That helped at 1200 rpm and below with my smaller 224 cam, so it makes sense that I would have to adjust VE at even higher rpms with the much larger cam I just switched to.
P Mack, I wound up only reducing the timing between 0.08 Gms/cyl and 0.56 Gms/cyl for best results. My reasoning is to reduce light load bucking without making the car bog on dead-stop take-offs. This seems to work great, and I may go back and reduce it some more at the midpoint and below.
I also just got done tuning the VE as sugested by Ragtop 99; results were so good I went back and did it again all the way from 400 to 2000 rpm. That reduced the raw gas smell and reduced bucking at the same time. Although there is still some jerkyness, I'm very happy with the improvement. For your C1 cam I'm sure this would be overkill, but for others with a 230 to 240 duration cam, here's the multipliers I ended up with for the VE adjustment:
2000 rpm 90%
1200 rpm 65%
800 rpm 63%
400 rpm 54%
I think I could even back it off further because I didn't induce any stumbling on take-offs at this point, I just got tired of messing with it. I left the 800 rpm point disproportionately high because it is below my idle at 1000 rpm, yet should help reducing bogging from a dead stop take-off. (I think the rpm drops below the 1000 rpm idle when I let the clutch out.)
2000 rpm 90%
1200 rpm 65%
800 rpm 63%
400 rpm 54%
I change my mind on this issue whenever I try something new... I have tried fuel and spark and...well everything. So now I went with an ungodly amount of spark at <.24 g/cyl using a 2005 5.3L truck spark table, and I think it helped a lot. I am going to look at my logs when I am done writing this as a matter of fact... I noticed that in the spots where I have bucking my g/cyl drops below what the car idles at. That is not right. My theory is that because of the overlap timing is not optimal...maybe reversion is causing it...I don't know for sure. But I know the cylinder pressure should not drop that low while you are opening the throttle and letting more air in. Adding timing will increase the cylinder pressure, and hopefully ignite the incoming charge before it has a chance to blow out which ever way it is blowing out. Off to the logs...
Originally Posted by P Mack
I can't seem to find any logs where my car is bucking, but can someone look and see what the IAC is doing in relation to the MAP and RPM when this happens?
Also, I have done runs with IAC locked, and fueling locked rich and lean, neither showed a difference. I tried it with timing locked, but I was not about to lock in the values I am working with now...50 degrees is a lot!
Another User - Did you say that turning off idle proportional fueling helped? I tried it a few weeks ago and it seemed to make my bucking a lot worse. Do you still have yours disabled?
