Just got my HP tuner
Old 12-20-2004, 02:22 PM
02Z28's Avatar
Default Just got my HP tuner
I have a 2002 Z28 6 speed and I was wondering what sould I do first with the tuner. I have installed LT headers, removed cats, 3" true dual exhaust. I have also removed the air pump and installed a 160 t-stat. The check engine light is on because I have no cats and no air pump. Any help would be great.
Thanks
Justin
Old 12-20-2004, 02:32 PM
LS1TECH Sponsor
foff667's Avatar
deleting the codes for the o2's would be a good start as well as turning off cot ...and changing your fan temp turn on/off's
Old 12-20-2004, 03:30 PM
02Z28's Avatar
Would you happen to know what codes I need to delete and how do I turn off cot?
Old 12-20-2004, 03:35 PM
horist's Avatar
um... scan your car.. whatever codes you're setting disable....
for COT just say "no" to the "enabled yes/no" option ....
I would suggest reading the manual (once installed hit F1... print it and read through it) it goes over the tables very well... and describes what everything does
Old 12-20-2004, 03:36 PM
LS1TECH Sponsor
foff667's Avatar
137-138-140-141-420-157-158-160-161-430 and where it says cot on/off youd want to set it to off
