SD Tuning with EFI Live, Wide Band, and LS1 Edit Questions.
Guys, I am in the process of putting in a 239/246 .649"/.613" 106lsa 106icl cam in a stock 01 shorblock with home ported 5.3 litre heads cut .030" (yes I have flycutt the pistons).
I believe I will need to SD tune to get this thing to have good manners on the street but haven't made up my mind yet. (cam has 5.5 degrees more overlap at .050" then the TREX).
What would be a good way to go about tuning my car in SD mode using EFI Live, the LM-1 Wide band sensor (no rpm, map, logging capability but will get the cable to log these if necessary and I believe it will be), and LS1 Edit. I already have ls1 edit unlimited for 97-04 cars so please do not try to convince me to by HP Tuners which I believe makes SD tuning a breeze.
I set the car up in open loop before tearing down (really didn't have to tune the ve table to do this, just unplugged the 02s). Wood a good way be to plug the 02s back in and try to tune the VE tables to get near 0 ltrms at all throttle and rpm positions. I would want to reset my maf values back to stock correct? I have a SLP 85 mm maf if that makes any difference. What all would need to be adjusted to do this? I do not have EFI Live Pro so I cannot reset things with EFI Live, only Edit.
If I run speed density I will be scrapping the maf all together after tuning and using a section of 4" high temp silicon hose to bridge the lid to the tb. Will this impact my ve's enough that if I tune from ltrms that my a/f will be way off after removing the maf?
Any help or suggestions will be appreciated. The car will be up and running by the end of this weekend.
Originally Posted by Slowhawk
You can tune it either way.The car can be done fairly easy in closed loop if you wanted.
If you think differently let me know.
