lowering engine temprature and disabling CAGS using LS1edit
Old 01-03-2005, 10:22 AM
Abdullah's Avatar
Default lowering engine temprature and disabling CAGS using LS1edit
i just got the LS1edit yesterday. i want to lower engine temp and disable CAGS. where to set fan operating temps to lower engine temps and where to set the CAGS mph values to disable it?
Old 01-03-2005, 10:28 AM
LS1TECH Sponsor
foff667's Avatar
i always set the tps to 0 for cags and fan temps i wouldnt modify unless you have a cooler thermo otherwise its pointless, what temp thermo do you have?
Old 01-03-2005, 10:36 AM
Abdullah's Avatar
i think i have the stock thermostat, i will get the 160 degrees thermostat if i put the 160 thermo where to set the fans temps? thanks.
Old 01-03-2005, 10:39 AM
crainholio's Avatar
There's some room to lower w/ the stock thermostat in place. I'm finding the stock 'stat opens at 190degF, fans don't come on until much hotter.
I have my fans coming on at 200degF, turning off at 195degF. That's much cooler than the stock fan settings, but doesn't put me up against the thermostat.
I'd go this route rather than a 160 thermostat personally. The LS1 seems to like to be run hot.
Old 01-03-2005, 11:11 AM
LS1TECH Sponsor
foff667's Avatar
i believe the stock fans turn on at 225 & 235 respectively so moving the turn ons to 200 and 210 i think would be a good move.
