Fuel Injectors, IFR Table, and Scaling
Old 01-19-2005, 01:24 PM
TAQuickness's Avatar
Default Fuel Injectors, IFR Table, and Scaling
Just need some help to see if my understanding of the IFR table and how to scale for new injectors is correct.
Fuel Injectors:
'00 Stock Fuel Inectors - 26.6 lb/hr @ 400 kPa
Delphi 32 lb/hr injectors - 31.6 lb/hr @ 300 kPa = 36.5 lb/hr @ 400 kPa
400 kPa difference (delphi over stock) = 137.22%
IFR table:
Look up table for the PCM to determine the injector flow rate (grams per second) at a given MAP (kPa).
Scaling:
To properly scale the IFR table, I need to multily the stock numbers by 1.3722
Is my understanding correct?
Old 01-19-2005, 01:31 PM
horist's Avatar
31.6 @ 3 bar, 400kpa/300kpa = 1.33^.5 = 1.155 so 31.6@3bar is 36.49@4 bar
stock injectors are 26.6, 36.49/26.6 = 1.372
yup your numbers checkout, scale your stock table by 137.2%
Old 01-19-2005, 01:39 PM
Thanks for the quick response.
