Use of Main VE Table
What does the PCM do with the values stored in the main VE table?
From what I can gather (nutshell version), the PCM takes the value from the Main VE table that correspond with the appropriate kPa/RPM reading, reads the MAF, IAT, and possibly the ECT, calculates a g/cyl figure, opens the injector, fires the spark.
Haven't got to that part yet. I got my IFR table set up proper for my injectors, now my LTFT's are way north of 0. I plotted a map of my calculated VE and found the logged data to be ~15% less than the data used in my main VE table. Anyhow, when I get to screwing with the spark tables, I'll post my theories.
Airmass Calculation
This is the original thread on hptuners. It's been posted around here a few times too.
To summarise:
1. High RPM behavior is totally based on MAF
2. Mid RPM behaviour has an allowance on Steady MAP behaviour before it switches to Unsteady MAP
3. Low RPM behaviour (where the bulk of the fuel cells are) is dictated by unsteady MAP behaviour that is still mostly dominated by the MAF input with small tweaking from SD)
Originally Posted by Another_User
My theory is that the spark causes something I call "combustion". I will post more after I verify my theory.
Originally Posted by P Mack
Airmass Calculation
