F.A.S.T. or PCM for LS1?
Hi All,
The LS1 is going into a road-race kit car. Not sure of the final design on the engine yet, but it will likely be a 388. Need to pass SMOG, so will have a reasonable cam, cats (and cutouts ). Have been reading about the F.A.S.T. system, but don't know too much about the stock or ASA-PCM (and cam).
Since only the LS1 is being transplanted, which do you think is better suited to controlling it?
Stock PCM
ASA-PCM
F.A.S.T. System
I am thinking F.A.S.T. for the following reasons:
1. Frequent software updates (soon to have traction control)
2. Flexibility (can be used on just about any motor)
3. Ease of use (software appears logical and intelligent)
4. Cable (doesn't need special VIN cable)?
Cons to F.A.S.T. system:
1. More folks available to program a PCM
2. Cost (PCM and HPTuner/LS1edit is probably cheaper)
Open to all suggestions. Your comments are greatly appreciated.
Stock PCM
ASA-PCM
F.A.S.T. System
LS1TECH Sponsor
Every pro you listed applies to HP Tuners as well.
My car is a transplant car as well. I have my own custom race harness and PCM. All my factory gauges work and the PCM controls most of my car..
My next powerplant will be LS2 with a custom harness and LS2 PCM.
GM PCM is the most powerful engine management system I have seen that you can use.
- Keith, HP Tuners
- Keith, HP Tuners
- Keith, HP Tuners
- Keith, HP Tuners
I have to read more about HP Tuners. Thanks for the heads-up. Didn't know about that product. Glad to see someone is competing with LS1edit.
LS1Tech Co-Founder
Will your kitcar go thru OBDII testing, ie. will they plug into the car? If so, you might want stock pcm cuz FAST programming changes are made thru the FAST cable which is different.
If you need:
custom harness
pcm
02 sensors
hpt or competitor
I"m guessing $1500 or so?
BS3 might be like $2300 but you might need to customize the harness depending on how you mount stuff.
If you need:
custom harness
pcm
02 sensors
hpt or competitor
If you need:
custom harness
pcm
02 sensors
hpt or competitor
If you need:
custom harness
pcm
02 sensors
hpt or competitor
