Can 99+ knock sensors be used on a '98 LS1?
Old 02-07-2005, 06:31 PM
V-10 Killer's Avatar
Default Can 99+ knock sensors be used on a '98 LS1?
If I changed the wiring harness too, could the newer knock sensors be used on an older block/PCM?
I'm just wondering in case I fail to be able to de-sensitize them via HP Tuners.
Old 02-07-2005, 06:53 PM
wait4me's Avatar
yes you should be fine,
Old 02-07-2005, 06:54 PM
dissonance's Avatar
Yes you should have no problems if you use the newer style knock sensors and harness...
I have a set in my 98 and have not seen a "real" difference in reduced knock. Looking back I would do it again yes... because the 98 have had known bad sensors.
make sure you do the RTV seal TID
Old 02-07-2005, 08:28 PM
Great, I wish I'd have thought of this 3 months ago.
I just put two brand new replacement knock sensors in while swapping in a new intake, old style of course LOL
Where's my sign
Close enough
Old 02-07-2005, 10:31 PM
John_D.'s Avatar
I desensitized mine ('98) no problem using hptuners.
Old 02-08-2005, 10:22 AM
D3IMOS's Avatar
How did you do that?
Old 02-08-2005, 11:20 AM
tici's Avatar
Yes please, tell us about the desensitation!
I did it using some resistances, it works but who knows when it becomes unsafe?
I had to add 5 to 10 Kohm t oget raid of the KR.
